Engine cavitation
bazza12
Fear Group,
I have recently purchased a second hand 26ft long, 8ft wide boat which I am using as a dive boat for my business. The boat has a V shaped hull at the bow and a flat bottom at the stern. It has a new 200hp Yamaha engine.
We have noticed that even in relatively calm conditions the engine is cavitating badly (large increase in rpm with no increase in speed). We have tried raising and lowering the engine in the water to no effect (phyiscally re-drilling engine mounting holes, not just using the tilt). The engine is currently mounted as per Yamahas specifications but cavitation still continues.
We don't have any problems with purpoising but the boat will slide if we do sharp turns (I guess this is due to the flat bottom and we simply don't do sharp turns with customers on board anyway so this is not a big deal).
I was hoping that people with more knowledge of boat handling than I do can come up wih suggestions to solve the cavitation problem. At present I am unable to use the boat!
I have read about hydrofoils such as the Stingray and was wondering if this would help? I don't particularly want to drill holes in the cavitation plate of a new engine but it it is the only solution am happy to do it (I work on a tropical island so a warranty doesn't really mean that much to me!).
Any advice would be gratefully received.
pduquette
Ensign
Re: Engine cavitation
Are you sure the prop is not slipping on the hub?? If your a/cav plate is even w/ the hulls botom +/- 1 1/2" and you cant get continuous bite from the prop , I'd suspect that first:)
Irv964
I would suspect a spun hub too, sounds like it has to be that or the motor is not the right one for that boat?
The large cavitation plate should be level with the bottom of the boat when fully trimmed down, if it is way higher than that then your lower unit/shaft is too short? Good luck..........Irv964
JB
I agree. Try a different prop.
tashasdaddy
are you trimming out too far, if not, i agree ^^^.
Randybeall
Any chance you could take a couple of pictures of the installation, side view close enough to judge prop and anti-vent plate alignment with the bottom?
Splat
Sounds like a spun hub.
Mark the hub and the prop in a line with some kind of marker and run the boat in the water. Then pull it out and inspect. The line should not move.
Bill
