i have a 19.5ft tahoe deck boat with 4.3 mercruiser bravo 1 outdrive. dry weight is around 3000lb. it has stock prop. want to know what a good prop would be for all around use. lots of cruising, fishing, and some tubing.
To give you the best advice we need to know prop size(usually on the barrel or under the prop nut);present max rpm and speed.(GPS is best)and the max recommended rpm range.(usually a label on the motor).
