Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I am trying to figure out where to release the overflow hose from my live well. Instead of having to drill a new hole through the hull, can I add a T connector to where the bilge pump exits the boat and connect this hose there?
Re: Can I connect a T connector to Bilge hose to exit my overflow drain?
no the bilge pump should be total independent, it could also back flow into the bilge, as you cannot put a check valve in the bilge line. get the drill out.
I've seen several "tee'd" into the bilgeline around here. They put a big loop in the bilge line with the tee on the low side of the loop towards the hole in the hole. The loop keeps it from backing up into the bilge.
Any loop or rise above the exit fitting puts more head pressure on the pump and you lose gph. An inline backflow valve is the same, needs pressure to overcome initial resistance. That could make a difference in any emergency when the bilge pump is needed at full capacity.
