JustJason
- Aug 27, 2007
- 5,367
Not sure if this needs to be in nonboat tech section but since the original post was in here i'll post this in here.
2 weeks ago I edited Don's "how to test your boats fuel system" and added some pictures of my own. (it's in the FAQ section here if you need to reference it. http://forums.iboats.com/showthread.php?t=283363 )
A fellow Iboater, who i've chosen to allow to remain anonymous unless he chooses to jump on this thread, advised me through PM that I need to make some changes to the way I do things. I do not agree, which is why i'm posting here. I'd like to hear what you all have to say, and by all means if i'm wrong i'd like to edit the fuel system thread so everybody, including myself, has the most accurate, most up to date information.
1. He stated
I replied with
He follows up with
And I reply
He replies
my reply to that was basically I don't agree, and i'll take it to the boards. What do you guys think? Am I wrong? Are all my gauges plumbed incorrectly?
If I am I humbly bow, but i've been doing my tests the same way for years, and I haven't had a problem. In a nutshell... is pressure equal in all of the lines, regardless of size? I believe it is.
Either way my post in the FAQ section was about restriction testing, not pump output, so I don't know how the user got started on pump output. But if line size to the gauge also affects restriction testing (and again, i don't believe it does) Chime on in and say so!!
Jason
1. He stated
anonymousiboatsuser said:better change the gauge line to the same size of fuel line or ur readings are going to be off!!
I replied with
captjason said:Huh? Are you talking about the post I wrote on boat fuel system checking in the FAQ section?
Honestly I've never heard what you just said before. My low pressure gauges, as seen in that post, uses something like 3/16-1/4 inch line. As well as my higher pressure fuel injection gauge, my oil pressure gauge that goes to 100psi, and my transmission pressure gauge, that goes to 400psi, all use realitively small line. Are you saying that all my gauges are incorrect? They are all brand name tools. A mix of Matco and Snap-on. Why do they come plumbed that way? There is no way to change the line size to the gauge.
Some I'm curious as to why you said that. A fuel pressure system is nothing more than a simple hydraulic system, in which the pressure is equal in all the lines regardless of size.
He follows up with
anonymouseiboatsuser said:well the clear line needs just go to the gauge not the boat lines
anytime you reduce size in a fitting you will get a bad reading
i just replaced the nipple in my gauge
in all our factory traing this year, they pushed it hard, cuz guys were scewing up
im just letting you know the new standard now
and you must run the motor for at least 10 mins wot to check things
And I reply
captjason said:I'm not looking to argue or anything, just learn, because I never heard what you are saying before.
Why would I need clear line to the gauge? The only reason I use clear line at all is to look for air bubbles and possisbly crap coming up from the tank. If I put clear line in between the gauge and the T-block I wouldn't see fuel flow there, and I wouldn't see bubbles.
On to the change in fitting size. Let me ask you a question, wether it's high pressure fuel injection, or a low pressure mechanical pump. Isn't it all just a basic hydraulic system?
Lets say for sake of arguement, that I had a mechanical fuel pump and a carb. Lets say I'm using 3/8ths line between the carb and the pump. With the seat in the carb fully closed, lets say the mechanical fuel pump is capable of 7psi. If i splice in a tblock and line that is 3/8th, but the line that goes to the gauge is 1/4 inch, my gauge is still going to read 7psi. Why are you saying it wouldn't be? I've never heard it before. In a hydraulic system isn't psi equal in all lines?
As far as running the motor for 10 minutes at WOT. I do agree that to fully accurate the test needs to be done in the water under a load. But In the post I said it can be tried on the muffs because alot of times things will show up. so no questions there.
On all my gauges, especially my high pressure gauges which use quick connects, the inlet to the gauge cannot be changed as they are built into the gauge housing itself. Even my snap on gauges are that way.
Are you doing your factory training in house or are they shipping you off someplace like MMI?
Just curious.
Jason
He replies
anonymousiboatsuser said:that is right, clear for air bubbles and crap, u will see it in any clear line. but you only need it at the gauge line, everything will flow that way if you keep the gauge lower than the place you are testing. u could use all clear, but the problem with clear is that it goes bad, so replacing all the clear is OK, I'm just saving cost shop wisecaptjason said:Why would I need clear line to the gauge? The only reason I use clear line at all is to look for air bubbles and possisbly crap coming up from the tank.
u r wrong on that part, air rises, liquid sinkscaptjason said:If I put clear line in between the gauge and the T-block I wouldn't see fuel flow there, and I wouldn't see bubbles.
hydraulic? i guess u can call it that way. so your theory is = 1" pipe at 100psi, if that went down to 1/2" pipe it would be 100 psi, wrong. just look at the trim and tilt systemcaptjason said:On to the change in fitting size. Let me ask you a question, wether it's high pressure fuel injection, or a low pressure mechanical pump. Isn't it all just a basic hydraulic system?
only air bubbles, cuz at wot u might not get over 3 psi at pump, but at idle you willcaptjason said:As far as running the motor for 10 minutes at WOT. I do agree that to be fully accurate the test needs to be done in the water under a load. But In the post I said it can be tried on the muffs because a lot of times things will show up. so no questions there.
captjason said:On all my gauges, especially my high pressure gauges which use quick connects, the inlet to the gauge cannot be changed as they are built into the gauge housing itself. Even my snap on gauges are that way.
MMI was training, did that learn a few things, the factory stuff is taught by factory guru's who see it everyday. That is what i take 4 times a year.I make the shop pay for it
Jason
