Pablo Cruiser
- Nov 11, 2008
- 3
I have a 1991 Ranger bass boat with a 150 HP Evinrude. This past weekend it refused to start. It acts as if there is no power to the remote control box. There are no beeps when the key is turned to on position. The motor trim rocker switch on the top of the throttle handle does not work. The motor trim switch on the side of the motor does not work. The motor trim toggle works in the bow of the boat so I could raise my motor. Nothing happens when the ignition key is turned to starting position. I could find no fuse or in line circuit breaker for the remote control box. The three prong cable below the ignition key is intact. There are 3 wires going up the bottom of the handle for the throttle lever.
I have tried everything I can think of but come up zero. Any hints or help would be great. I am lost and unsure if a new side mount remote control is in order.
Thanks...Pablo
Thanks...Pablo
