Almost Finished 1 last Q about Gel Coat
Alpinegold
I want to thank everyone who responded with info on how to restore the Gel Coat's finish on my 1978 Ranger V178. Everyone says I must have repainted the boat as there is no comparison. The finish is a medium to dark brown base with gold metal flake. I wroked my way up from 360 wet sand paper to 2,000grid. Then I used 3 M rubbing compound and got down to the gel coat finish looks great.
Here is my question: I can still take a small bit of rubbing compound and with a micro cloth can rub on a finish area and dependiing on how hard I rub, I can still see a ton of black what I am assuming is oxidation on the cloth. Does this mean that I still need to take some 2000grid wet sandpaper and continue working the finish?
ondarvr
Re: Almost Finished 1 last Q about Gel Coat
What, no pics.
You can do that even on a brand new surface, it just means the compound is working, it?s supposed to be removing a small amount of material when you use it. The coarser the grit, the more it removes and of course the opposite is true for the finer grit compounds.
Alpinegold
How do I know I've got the finish at it's peak?
