I have a 1992 25 HP johnson that very intermittently loses power while at full throttle (mostly). I at first, in the spring, suspected water in the gas but this was not the case. All filters are clean. At high speed the motor will very suddenly power back a good 50 to 75% but never stall completely, and resumes power very quickly on its own. This may happen once or maybe 2 or 3 times in quick succession. The carb has been cleaned and a new power pack put in. I have tried 3 gas tanks and 2 hoses and it happens with all of them. The motor may run beautifully for 2 days then all of a sudden power back. I suspect a fuel problem but my mechanic keeps insisting it cant be the fuel pump as he has never replaced a fuel pump on these motors. The motor has loads of power and idles beautifully without powering back.
