Extra Fuel Tank Install Question
mystiko
We want to add an extra diesel fuel tank to our boat.
The main tank is 40 gal aluminum and has two returns..
One return from the main engine which is Yanmar and the other is from the AC generator which is a 6kw Ficher/Panda.
We are planning to add a 20 gal. reserve tank, and a12v fuel transfer pump to move fuel to the main tank.
How do we access the main tank to allow this transfer to happen? Do we have to drill out a new hole in the main tank and add a new fitting? Or can we simply cut into one of the return lines with a ?T? and have the reserve fuel enter the main tank this way? Would a check valve be necessary or will gravity just allow the fuel to move. What about an anti siphon device? Will one be needed, if so where.
Thanks for your help. Please email any response to: jeffrey54@comcast.net
oops!
Re: Extra Fuel Tank Install Question
hi.....welcome to i boats....a really good place for bpoating information and to meet like minded people
we will need more info on your boat for proper information. there are several different transfer methods.
as far as e-mailing you the responce......if you go into your personal options...or click the user cp button....you can be notified via e-mail when you have a responce.
these forums exist to have a record of the replys so that other people in the future that have the sams question can find the answer.
cheers
oops
