starting problems
fisindad
hey guys new here , but i got a johnson 115 seahorse v4 outboard , im having a starting issue i would luv sum help with so i can get back on the wata , it ran great last year but left me stranded when this prob. accurd, ok the starter will turn the flywheel about 1/2 way then stop , the starter will cont. to turn , i took it off to have it tested @ my local advance auto n the sells guy said he's nt sure what the starting amps r supposed to be, it wasnt even peaking 1000 amps so my question is coud this prob. be the starter or something else? it had a brand new battery ,witch killed a cell n had to get a new 1 havent installed it yet , any help or info would b greatly appricated! thanks
tashasdaddy
Re: starting problems
what year/model is your motor?
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
F_R
So the flywheel stops but the starter continues to run with the bendix STILL ENGAGED, is that what you are saying? The starter bendix drive is shot (slipping). Not all of them can do that, but some can. However if it is kicking the Bendix out, the starter or cables need attention as already mentioned.
fisindad
ok thx 4 the info guys ill try lookin @ the solenoid everything else looks good, ill get bk to u on the model n in answer to F.R 's question , yes thats correct n yea the battery that went dead was brand new lol but got an exchange , the starter will jump up , start to turn the flywheel n then drop down a little n cont. to spin. didn think about jumping the starter , would covering the battery leads with liquid elec tape b a good idea to keep them from corroiding? the battery's in a box but does sumtimes get wet. thx again 4 the quick reply i hope to get this thing running again soon the biggg fish r biteing !!! :cool:
fisindad
ok i got this starting problem fixed i think, now motor will turn over but wont start? could this still be a bad solenoid?
