Great site, I've searched for an explaination but haven't been able to locate a potential fix. It's 1997, 90 hp 60degree engine. She seems to start and idle just fine, at some point in the past, which may have been after a carb job...I just don't recall... I would accelerate and get up to about 5000rpms then the engine by itself would settle back to 4500, without moving the throttle back. Possibly related, occasionally upon acceleration before the boat hits plane the engine would seem to hit a sweet spot for a moment and really accelerate the way I recall it use to a year or so ago, an then it would back off that. This motor use to easily hit the 5500 mark and these days 4500rpm is the norm. I had found potentially a couple of minor fuel/air leaks and have repaired/replaced what ever I found. I at first thought it may be have a fuel starvtion issue.
Is their a WOT adjustment?
Might this be a powerhead/coil issue?
Could this simple be a throttle adjustment?
If you all could help out that would be great!
