Re: Electric Motor Battery Question
Sportyak II!!! MAN does that bring back memories!! Got one for my 12th birthday in 1972. Fished it 4-5 times a week (after school) with a MK 15 (10# thrust) motor. I got thousands of hours out of that boat and then my kids did. Actually just gave it a vikeing funeral t about 6-7 years ago as the bottom of the sponsons wore clean through from dragging it up the beach! What a great boat. Thanks for the memories!
Anyway, I have to agree that 55# is way overkill for any yak and/or conditions I've encountered. A 30or 36 would be much better suited in power, weight and shaft length. That extra motor capacity is going to add weight you really don't need and at the stem where you have the least bouancy. It's length may also be a PITA. Having said that, since you already have it, you should be able to run it at 1/2 speed (tops) to get max hull speed. ( Keep in mind, the yak is designed to go only so fast. Applying too much power will get you little more speed and make the hull squat/plow/waste energy.) That's a good thing because a battery sized to give you 90 minutes @ 46 amps is going to add crazy weight to your yak. (and IMHO, defeat the thing that makes yaks so great. i.e Ease of portability.) Since it sounds like you have a mazimizer/chopper circuit, that will further streatch your battery reserve as long as you keep the throttle set to the lower ranges.
FWIW, My buddy and I have had great sucess with series U1, 33 ah deep cycle, gel cell batteries sold for golf carts and wheel chairs. Pushing a 12' Canoe, it's not hard to get a an afternoon of on/off run time out of a 30# motor run at 2,to 4 of 5. ( That's like 8-20# thrust on a 30#). Worth a look as these run around 24lbs and are sized to fit in a hatch if needed. They are also made to take a beating and even run upside down without leaking. Anyway, If you keep your motor set low, and truely need only 90 min run time , you should be OK with one of these. HTH
