Hi, just a quick question as im having a problem with my 115 merc 2004 model.
Ive posted here and not on the similar thread so as not to hijak the other blokes thread
Today i lost the taco on the way home from fishing,the taco needle sits hard down when the motor is running.When the ignition is turned on with the engine off the needle rises up a bit.I checked the charge rate with a multi meter and it seems only a slight increase when the engine is running.from 12.4 volts to 12.9 with the engine idiling.So would i be correct in saying i should replace the rectifier.Im having to repair this my self as here in New Zealand at this time of the year its impossible to get the boat to a mechanic as they are very busy.
Cheers in advance, Wayne
