Maybe Someone Can Help
chinner546
I have an 82 merc 50 hp 2 stroke 4 cyl....i can go along with the throttle full open no problem but all of a sudden it seems the engine looses power then it seems to gain it back and so on and so on....just wondering if anyone has ever encountered this problem or know what the problem is ?
Plainsman
Re: Maybe Someone Can Help
Welcome to iboats!
Try giving the fuel bulb a few pumps when it does this. Could be a fuel delivery issue.
sschefer
This is a tough one but I'll take a shot. I'm guessing it's not a fuel problem but it can't be completely ruled out. It sounds to me like you're dropping a cylinder and the problem could be temperature related. With that thought it's going to be tough to find the cause without going through a guess and replace process. Because it comes and goes at full throttle I can guess that a plug is fouling due to poor spark. It's impossible to tell which one because when you back off it comes back so shutting down and pulling the plugs would probably not show anything. You could test the coils but they will probably test good also. However, heat can cause a coil winding to separate and stop functioning at full capacity which would cause your symptom. The problem you have is which coil is it? It probably isn't the trigger coil because that would effect all cylinders and there would be a huge loss of power. I suspect it's one of the four ignition coils. I'm afraid my theory is going to require an easter egg hunt but this is where I would start. Buy one new coil (they are all the same) and replace and old one, one at a time. If you get lucky, you'll hit it on the first shot. If not you're only out the cost of a single coil and changing them is relatively easy.
tashasdaddy
when it starts to act up, check spark immediately. as said could be a coil heating up and failing. is the vent open on the fuel tank? as suggested also try pumping the bulb.
