I have a 1994 Volvo Penta 3.0GS. I have tryed to set timing to 1 DEG BTDC with a Jumper when I removed the jumper led and recheck timing idling it is still at 1 DEG BTDC when RPM is increased timing does not change until revs get to about 1500 RPM and then jumps up like it is stuck in base mode? Engine starts fine, slow onto the plane top end RPM is only 3900 RPM. New Spark plugs, Fuel, Fuel filter, Coil, Checked water trap and carb filter. Are there any checks I can do to EST? I have read to check that 12 volts are coming from the two coil wires feeding EST. What does the Distributor pick up coil do could this be the problem?
