Re: Fuel Consumption for 9.9 hp outboard
your choices will be 3, 5, or 6 gallons. If you are an infrequent user I would suggest a 3 gallon version. This will ensure you use most of the fuel with each outing, which ensures you always use fresh gas. The larger tanks obviously would allow longer run time but again, if you are an infrequent user, you would likely have lots of fuel left that has a tendency to sour. If you use the engine frequently, then a larger tank is in order. Just my humble opinion.
