I just purchased a used 150hp, 2.5L carberated 1998 2 cycle engine, and wanted to know what the compression should be??
Also the oil injection was inoperative, and I was told to use 50/1 oil mixture.
Questions:
1. Should I remove the oil metering pump and shaft or is it ok to leave it??
2. Lower port side cylinder reads 90#, all others 110-115#, should there be any concerns??
3. Temp is 160F at idel, drops to 120F at anything over 1500RPM, is this normal to run cold at <RPM's??, is there some sort of bypass of theromastats at higher RPM's??
4. Running a Ron Hill chopper 26"P, engine turns 5800RPM@63MPH on 19' Bass boat, what is the RPM range for this engine??
5. Is there a engine shutdown system for high tempeture due to lack of oil in fuel, or falty water pump??
6. If engine were to be subject to low oil conditions, besides overheating of cylinders, would the bearings be at risk??
Engine runs fine on premix, just needed to know the specks on this engine, and any warning/safety things for this model engine besides the beep beep alarm.
Questions:
