crackedglass
- Jan 4, 2009
- 206
I've been looking for a good used aluminum V hull for some time now with no luck. I'm looking for either a tiller steer or stick steer model with tall sides. I want it for river and back bay use. I want an old fashioned open boat, nothing special. I have a good 25hp to use, 20" transom and several trailers.
I've looked at new but all are way out of my price range. All of the used boats I've seen have either been priced higher than new or are too light duty or low sided for what I need.
Does anyone have an model suggestions I should be looking for?
I've looked at about 50 used boats, all have been priced either close to or even above the cost of a new boat. I've even considered a modified V style jon boat if I could find one wide enough but they seem pretty far and few between. It needs to handle three full size adults, or no less than 900lbs of passengers plus tackle, fuel, trolling motor, etc. I'm over 6' tall and nearly 300lbs, and I'm the smallest guy in the bunch here. Most of the boat's I've looked at have also had only a 600lb rating, which didn't make much sense to me since they were far wider than my 17' glass boat which handles all of us with no problems and is rated at 1250lbs. I've not yet seen a small boat that is rated to handle three guys. One of the problems I also have to deal with is a hp limit on some lakes of 10hp, I need to be able to swap out the motor easily for those lakes, which is part of the reason for wanting a tiller motor.
(Its not likely I'll find a boat that will go where I need to go and still be able to handle the added weight of having a second motor hanging on the back).
