Re: suzuki dt140 sputtering problem
To eliminate the fuel as a problem, I would suggest running new fuel in a separate tank. From there you can troubleshoot other problems.
Yes, stabilizer all year, just because you typically don't get the usage out of an outboard fuel tank like you do your car. StaBil, StarBrite, even SeaFoam all say they stabilize. I like StarBrite myself. I have used it for over a year and have had good results. I had to empty my 30 gallon onboard tank for an extended down time and no moisture or odd colored fuel. It was all clean and dry.
