SS MAYFLOAT
- May 17, 2001
- 6,372
My rig has the VP 280. I have 2 helms which each has one cable going to the outdrive. The cabin helm cable I replaced 2 years ago and it is in great shape. It works so freely, I had to check to make sure it was still hooked up.
Towards the end of last season, my bridge helm shifter control started to bind up a lot. While docking, I was in reverse and went to shift into forward and the end of the cable snapped off. This was a bit frightening since the boat was headed for a big stone covered bank. Luck had it I was able to crank the steering wheel and used the outdrive as a rudder to drift into a vacant slip.
When I was ready to haul out for the winter, the cable wouldn't budge one bit. So I got in the water and took the back cover off the outdrive and unhooked the bridge shifter cable. That is when I realized that the cabin helms cable was in great shape. At least I was able to get it all loaded up.
I took the old cable out and found a few bad spots in the jacket. The wire re-enforceing was rusted in each of the bad spots.
One of the issues is that the outdrive end of the cable stays submerged in water throughout the season. What I want is to find out what cable is fully corrosion free. No steel, but stainless would be best. Any ideas? BTW, it needs to be 24' long. Thanks..........SS
