Re: 1971 evinrude 25 hp
decarbing will clean the guts, built up carbon, cause excess smoke. using synthetic oil cuts down on smoke. a reuilt and properly adjusted carb, make it run better and cleaner.
http://forums.iboats.com/showthread.php?t=244013
http://forums.iboats.com/showthread.php?t=167352
Decarb, take a can of seafoam put 3/4 of it in the gas tank, with only 1 gallon of premixed gas. put the rest in a spray bottle. start the engine, and let it come up to temperature. then remove plugs, and them some real good shot of seafoam into the cylinders, replace plugs, let sit 15 minutes. restart, and spray the rest of the seafoam into the carbs, so the the motor almost stalls, wait and repeat until the seafoam is gone.then take for a wide open spin. then put in new plugs, ad premixed gas to the tank, and take it for a wide open throttle spin. it is going to smoke like a house on fire, during this process.
