Hi,
Force 120hp Outboard
Trim Pump # 37-43530-1
Bracket Serial # OEO62505
I have had off & on issues with the trim / tilt. Sometimes it will not do anything other than I can hear the electrical do one click. In the past it would run for a bit and then finally the outboard will lift or lower. I lifted the outboard and checked the fluid. It is a pink color. Does that seem right?
Does anyone have an idea that can help me fix the trim / tilt?
Thank you for your help,
Adam
Adam
