Expidia
- Aug 26, 2006
- 2,374
50 degrees today, time to get busy for the first splash down. It's coming up quick (I hope).
So I put both my aluminum props on my work bench today to paint them correctly this year. I have a 13 pitch Merc OEM and the other one is a 12 Vortex which I bought last year to carry as a spare and to put on when there is going to be more than two of us on the boat.
Of course I banged each one up last season (one twice) on the occasional sandbar that came up out of nowhere when I was not paying attention to the GPS. Hudson River bottom contours are tough because once you leave the channel to fish, the bottom can change from week to week because it's muddy plus it has a 6 foot tide to deal with even though it's a fresh water river. And lotsa floating debris like branches, LOGS and TREES
So each time I got them back from the online prop repair shop I noticed the paint would chip away in spots as soon as the prop even smells sand again
I called the shop and they said they just spray them down with black Rustoleum and ships them back real quick.. They don't use any primer. For the $30 bucks or so they charge, I figured everything?s a trade off.
I hate the look of anyone's prop (especially mine) with the paint all knocked off when they pass me on the highway. Just says to me they must be as bad a navigator as I am
. . . so to fool everyone into thinking I can actually navigate a boat as soon as I knock some paint off an ear or two I spray it when I get home. Stainless must be nice!
But last season after touching them up with a little grey spray primer followed by the black spray just normal use pops some paint off again in places.
So I asked on this forum last year what's the best way to paint yer prop?
Consensus was that I should first use "self etching" primer spray.
So this year I'm trying tp start out right . . . first.
I picked up a can of Dupli-Color self etching primer in Advanced Auto for about $5.98. It's green, but that makes no diff to me as it's going to be covered in black anyway.
Sanded both props down a few hours later with a Black and Decker Mouse vibrating sander. It has a nice pointed shape and it really made fast work
out of removing the chips and roughing up the whole surface of each prop.
I wiped them clean with some turpentine and put both on a length of copper tubing and set the tubing between a fence in the back yard and lightly sprayed both props with the self etching primer. Says best used in 70 degrees, so since it was only 50 I moved them back down the basement to dry.
Next step will be to lightly sand them down with 400 grit wet/dry paper as the can says and then a coat of the black. I bought two cans of the QuickSilver Mercury Phantom black last year at West for $12 each. Not cheap, but a little should go a long way once I'm only retouching chips and not the whole props.
I also bought the QuickSilver grey primer, but I called my autobody guy (guess I can't drive a car that well either if I have an autobody guy! it's OK, I have him on a retainer). He said to just lightly spray the etching stuff on, sand it a little and I should not need to use the grey primer before I spray the black coat on.
I'll report back on how well this method I used holds the paint this season. The OEM paint that came on the Mercury prop gave me about 100 hours without any paint coming off under my normal use until I hit an under the waterline stump one day. So I should be able to keep the paint on if applied correctly. I hated it last year when a big blotch chipped off a prop ear each time I painted them, I guess cause I omitted the etching primer step last year and just used the grey stuff first.
Thanks for the input last season on what I was doing wrong . . .
Starting off the new season with freshly painted props . . . now if I could just manage not to hit anything this year
