Re: change from 2 blade to 3 blade?
I'm not familiar with a River Rat boat, but if its on the heavier side for a 14' boat, and your two blade prop is the same pitch as the three blade, you'll probably like the two blade better.
I use a 1969 Johnson 6hp as a kicker on my 17.5 foot trihull. I bought a three blade prop a couple of months ago, thinking that it wouldn't be much different than my two blade, because the pitch is the same. I don't have a tach on the motor, so I can only judge by ear and speed, but I noticed a significant difference between the two - the three blade does not wind up nearly as much and my boat is about 1 mph (GPS) slower with it. Given that I only get about 5 mph with the two blade, that's a significant difference.
Obviously, your boat is much lighter than mine, but it seems like a 14' fiberglass boat is alot of boat for a 6hp motor. That being the case, the three blade may be too much prop for it.
When in doubt, however, try it!
