I am hoping someone can help clear up some of my confusion about fiberglass layup. I?ve been reading a lot of the posts on here but I can?t quite put the pieces together into a clear picture. There seem to be so many different options and variables that it's a little overwhelming. If I understand correctly, when using Poly resin you need to alternate between layers of mat and cloth right? What I can?t figure out is what weight of mat and cloth and how many layers are needed. I am doing the transom and stringers on a 16? tri-hull.
Would 1.5 oz CSM and 8 oz cloth layers give enough strength or will I need heaver weight? How many layers should I use on the transom and stringers? Would 2 layers of tabbing be enough (csm/cloth then another layer of csm/cloth)? Would the same 1.5 oz CSM and 8 oz cloth be good enough to cover the transom after its tabbed? Will one cover layer of csm/cloth work or should I use 2?
I know this is a lot of questions but I?m having a hard time wrapping my head around all of the options. Any tips that will point me in the right directions would be great.
