I have a 1994 Mercury 60 hp that needs the impeller or water pump replaced. I have loosened all the nuts and bolts but it will not drop. I cannot figure out how to disconnect the shift linkage. This seems o be holding it up as the rear of the lower half ill drop slightly but the fornt will not. Is it the shift linkage? Can someone give me step by step on this? Thanks in advance for the help
