1987 48 spl has a knock or rattle?
mdcwells
I have a 48 spl that is either knocking or rattling. You can hear it well at idle and a low speeds. I pulled the plugs and moved the cylinders to the top. When I push on them and they start to go down the flywheel spins with them right away. After seeing that I don't feel like it's piston slap. If I run in the tank in the garage you can hear it a lot better from the front of the motor than the back. I havn't pulled the flywheel yet (because that is no fun) but it almost sounds like something could be rattling. The motor runs tip top. Pushes a 16 ft alumacraft classic almost 40 mph. Starts good, idles decent. What do you guys think?
tashasdaddy
Re: 1987 48 spl has a knock or rattle?
if flywheel was rattleing, loose it would not be running.
kenmyfam
Any rpm range where it is worse or better ??
mdcwells
Seems worse at idle or lower rpms. It could be I just can't hear it when I'm running hard. Thought it may have been a timing issue, but timing is right on.
kenmyfam
Low pitch rattle or high pitch ???
Benny1963
have you run a comp check? may have collapsed piston skirt or cyl that has bad rod bearing or scuffed cyl .mine had knock i pulled heads and found one piston had colapsed a skirt from overheat but check under fly wheel first and check to bearing see if your flywheel has any play back and forth .
mdcwells
Seems like a low pitch sound. very steady. I'm taking this boat to lake truman to crappie fish in a few weeks. You guys think that is a bad idea?
mdcwells
The flywheel doesn't seem to have any play in it, I still have yet to pull it.
mdcwells
compression top cylinder 110
bottom cylinder 150
kenmyfam
bottom cylinder 150
That is wildly different. You should be within 10% on the compression reading. A lot of compression testers will give a lot of different readings but will usually give a good similarity. Both are good readings but I wonder how accurate your tester is. Can you try it again with another tester ???
mdcwells
I need to break down and buy a tester. I sold a different motor to a guy today and he brought his tester with him. We tested the compression on the motor I sold (1975 omc 25 hp) and it came up with 125 and 130.
We pushed the throttle wide open to get air through. Bottom cylinder came up right away.
mdcwells
Bought a new compression tester. Top 110lbs, bottom 145
mdcwells
Another thought. I traded a ruger 10/22 for a 1983 sea nymph with a Johnson 50 hp. The decks are badly rotted was going to do as a project. I have it tarped and put away. I checked it and it was 150 on both holes. Would it make sense to just put the 50 hp on the v bottom and keep the 48 spl for a parts motor. They seem to be very similiar. Or would it be a waste to use the 48 for parts. Only have about $150 in the 50hp and boat.
jonesg
Runs tip top you say?
Have you tried seafoam, could just be a stuck ring due to carbon or...
it might just be a bad head gasket, only cost you $10 to find out and you can inspect the bores.
Seafoam worked on mine, it started out with 60 psi, went up to 72psi with a 10 minute soak of seafoam spray, then adding startron to the fuel it crept up to 83psi after a few runs. Give it a shot.
mdcwells
I did just run seafoam in the last tank of gas
