I'm rewiring all of my dashboard gauges.  I understand the G terminals to be ground (black wire), the + terminals to be 12V which I've tied into the switch that controls my running lights (red wire), the S terminals where applicable are senders which connect to the device they are measuring from (I've used green wire for this).  My question is the I (ignition?) terminals -- I presume this to be 12V which is hot when the key is turned on.  I've used yellow wire to jumper these together, but where do I tie it to?
