Re: no fire at the points
You have too many posts going on the same problem. Here is your original on wanting to know how to test a coil.
http://forums.iboats.com/showthread.php?t=300831
What you should have asked is "No spark, why???"  then we could help you find why you don't have spark.
In the other post I said to file the points. Did you?, even stated they were probably glazed over.
In the future,when you start a thread on a problem of not having spark, stick with it till you do. Don't start up a bunch of new threads with each thought, you never will figure it out.
How did you "Clean the points"? did you file the contact surfaces or what?
You can have the worlds best coil on that engine, and if the points are glazed over, it will not work.
Put in some new points and condenser, adjust them properly and see if you have spark.
