Evinrude FICHT RAM won't start
ExtremeStratos
Hey guys i have a 2001 Evinrude ficht ram and it wont start, its all electrical! i was running down the lake and all my guages droped and i couldnt trim my motor, when i stoped and shut off my motor to check it out my motor would do anything and neither would my gauges, the fuel injection wouldnt start and i couldnt trim the motor. i think it could be the PDP but im not sure, anyone got any ideas?????
JB
Re: Evinrude FICHT RAM won't start
Fuse? Battery cables??
seahorse5
Since nothing happens and the gauges are dead, check the fuses in the stb. cover first, especially the one by itself between two relays. It that is OK, change it to be sure, then you will have to trace the 12V circuit from the battery to the key switch to see if there is a break or a bad connection.
