Re: ethanol and boat motors
There are few places in the country that go through temperature extremes as wide as those in the midwest (Minnesota, Wisconsin, Michigan, N. Dakota) and if E-10 was such a problem nobody would be moving at 20 below zero yet our cars start fine at those temps and our boats start fiine at 95 above. Cars running on E-85 have block heaters as at 85% ethanol there is a potential starting issue at extremely cold temps. E-10 simply does not pose a problem here and yes -- we do have 95+ temps in the summer with ungodly high humidity. If you are having fuel percolation problems you should let the engine idle for a couple minutes before shutting down. That allows everything to cool down. Percolation is fuel boiling in the carb. Vapor lock is a different situation. It prevents fuel flow rather than flooding. Our boats sit from late October to March/April with E-10 in the tank but most of have learned years ago that using a fuel stabilizer and running the engine long enough to get it into the fuel system is all that's necessary to bring the boat in the spring and fire it up. Stop the panic already. If you have a boat with a very large fuel tank, use a fuel stabilizer and keep the tank topped off. Add a water separating fuel filter and stop worrying. If you are worrying about E-10, E-15 and E-20 are on the way. Sleep well!!!!! The only time I will say I'm sorry you have to run E-10 fuel is if you have a fiberglass (not plastic) fuel tank.
