82 evinrude 140
me again
hey guys i notice on most outboards it has a pee tube so you know if the pump is working. well my 82 140 has no pee tube is that normal?or is that before the pee tube?there is no hole on side of casing like all others ive seen maybe a dumb question but would really like to know thanks
me again
Re: 82 evinrude 140
thanks thought ide ask but dont see it on my engine maybe im blind ran it today didnt get very hot to touch water pumps out the two holes on shft right under hood maybe i should replace the pump what do you think
kenmyfam
Re: 82 evinrude 140
If the motor is unknown to you to this point then change the impeller at least.
me again
Re: 82 evinrude 140
yeah i plan on it this week but only ran the motor maybe 20 minutes total in 2 weeks but i dont see a pee hole any where on this engine are you fimilar with this engine at all? never seen anything like it the engine case around where the cover sits is all smooth ?
emdsapmgr
Re: 82 evinrude 140
The telltale first came out in 1978. Any chance the powerhead you have on your engine is an older model? It is also possible that someone changed the outer exhaust cover to an older one. You can verify the age by the model number on the round silver disc on top of the block.
Vic.S
Re: 82 evinrude 140
I was wondering that too. The 140 first appeared in '77 (135 before that) and the diagrams do not show a telltale in '77 but they do from '78 onwards.
ezeke
Re: 82 evinrude 140
The exhaust cover should have the opening even if plugged. It will take the standard OMC/BRP NPT tell-tale fitting. See the bubbleback in the thumbnail.
me again
Re: 82 evinrude 140
no its a 82 its just nice to know if the pump is working im going out today and check it all out agin but if worst comes to worst ill put one in just to be safe
me again
Re: 82 evinrude 140
well my bubble doesnt have that screw on it if i can figure out how to ad pics ill post it anybody know how? thanks
Vic.S
Re: 82 evinrude 140
You .... again!
Either upload a small picture directly as an attachment. See FAQs for details.
Or upload a bigger picture to a Photobucket, or similar, account then post a link to it or directly in your post using the IMG code.
If using P'buckt limit the size to what P'bucket call "large", then it fits in the forum format.
ezeke
Re: 82 evinrude 140
The older exhaust covers from 1973 - 1977 135HP motors did not have the connection, but would fit the 1982 motor. There is no reason to change, because it is not the best place for a tell-tale anyway.
If you want to put one in, add it high on the engine in a manner similar to the V4 in the Engine FAQ forum: http://forums.iboats.com/showthread.php?t=222677
me again
Re: 82 evinrude 140
couldnt upload so i used my avitar well here is the bubble
