coastaltom
- Apr 1, 2009
- 2
My 88 spl evinrude had become almost impossible to move with the steering cable. I disconnected the cable from the motor and determined the motor was almost frozen on the steering bracket.
After reading some posts here, I found the port side grease fitting(I never saw it before) and tried to put new grease in but it wouldn't take. I used someone's idea of putting a MAAP torch to the bearings in hopes of melting the old grease. I also warmed the bracket, below and above the grease fitting as I thought there must be a channel in there for the grease to flow to the bearings.
Well, the tricked worked for the lower bearing and I have "new" grease coming out from the lower bearing but NOT the upper. My theory is the upper channel is still blocked and the grease is taking the path of least resistance to the lower.
How can I force grease to the upper bearing?
Thanks for your ideas and help.
