lunawhaler
- Apr 5, 2009
- 3
I just bought this motor on Saturday. When I got the boat I noticed that it was cooling properly, no water from pee hole. I investigated the impeller and found that it was not installed correctly. I purchased a new water pump housing (total kit) and replaced it. I also noticed that there were no washers on the spline of the drive shaft...which I have not replaced yet. Nonetheless, I hooked the motor up to the water and fired her up. The engine appeared to be cooling good now with a steady stream of water from the pee hole.
The problem is that I also noticed water coming from the first (top) cylinder spark plug!
Any recommendations on fixing this problem or troubleshooting it?
Thanks,
Tim
Thanks,
Tim
