Guitar Charlie
- Apr 6, 2009
- 13
Greetings.
I was recently given a two screw fishing boat with a pair of Volvo AQ 130d engines with matching 280 outdrives. I'm getting ready for the fishing season and replaced the impellars on both raw water pumps. These engines do not have radiators. The port side engine runs great and stays cool however, the starboard side engine is not pulling any water from the giant tub I have the sterndrive sitting in. I am able to blow on the inlet hose at the raw water filter and make bubbles in the tub verifying that there is no obstruction but I cannot rule out a possible air leak along the way. I did replace a leaky cylinder block drain tap that was leaking with a brass plug before I switched the raw water impellar...Any thoughts, I can't figure this one out.
Thanks,
Charlie
Thanks,
Charlie
