I have a 2002 merc 25 2str. When you put the engine in forward gear the locking pawl that engages the pin comes loose.There is a rod attached to the locking pawl that moves up to pull the pawl away from the pin as you increase the throttle in forward gear.Is this normal?--or is there something out of adjustment.I have never noticed it before but it appears dangerous if you were heading across the lake at any speed and decided to back off on the throttle.
Thanks in advance for any answers.
