Hello everyone, I just joined this group to try to get my grandpas outboard working for him again.
First of all I don't know much about outboards, I build hovercrafts, am building a v8 powered VW bug and work as an industrial mechanic so I have the mechanical abilities, but not the experience with outboards.....
At the end of last season my grandpas 1977 50hp merc stopped pumping water out of the tell tale. He had this happen a few years ago and he had to have the impeller replaced so he figured it was the same thing again. Except now he's retired and doesn't have the money to hire it done.
So I ordered a impeller repair kit and put it on this weekend. The old impeller was in rough shape, but not too horrible looking. I put it back together just as I took it apart and am confident that I put everything back together correctly, or at least the way it was when I took it apart, but its still not pumping water.....
He also had a mouse make a nest in it this winter and ate through a bunch of wires and a gas line. I re wired the engine and put on new gas lines, and the engine starts right up and runs great, but its not pumping water. Just a dribble out of the tell tale and I didn't notice anything coming out of the exhaust either.
I pulled the hose off of the tell tale and it was clear, I can blow air through the hose into the engine without restriction, and I also pulled the L/U back off and I can blow air up the water tube also with no restriction.
Any clue what else this could be??? And how I might go about fixing it???
Could a bad thermostat do this??? Maybe a rubber hose rotted off where it connects to the engine??? or???
Does anyone have a breakdown of the cooling system so I could see whats going on, or a breakdown of the engine so I could pull the lower housing off of the engine???
Any help would be appreciated.......... My grandparents are itching to get back out and do some fishing...............
THANKS for your time!!!!!!!!
