upgrade '73 115hp
rockyrude
I'd like to upgrade my 73 115hp with tilt only to tilt and trim. I've got a line on a '77 tilt/trim unit. Does anybody know if it'll fit?
ezmobee
Re: upgrade '73 115hp
The big design change over was in '78 so it SHOULD fit.
crb478
It will fit. Make sure that you get the mounting bracket and the switch and relay box with the unit. You can make the switch and rleay box if needed, but is is easier if you can just plug everything up.
ezeke
It will definitely not fit if it comes off a 1977 25" extra longshaft V4 Model.
rockyrude
Thanks for the heads up on the x-long shaft
