Hey all, new member. G/f has a '94 Sea Nymph, hasn't been run in about 4 years, had milkshake in the lower unit last time out. Will be replacing seals/impellers and interior on a very tight budget
Well we finally hauled the boat over to the house. It's nothing special, just a 16.5' aluminum V-hull with a Johnson 50hp on the back. G/f bought it new about 15 years ago.
Needs some work, the motor needs the carbs rebuilt and new seals on the lower end (changing impeller when I do that).
The wood floor needs to be replaced and carpeting redone. This is where my questions start. This is being done on a very strict budget. What is the best plywood to get? Is marine ply worth it and how much more expensive is it? Where do you even find marine ply? Same question pretty much for carpet. Just get a cheap indoor/outdoor carpet or marine?
floor
wore-out carpet
The dashboard is in really rough shape. Can you find replacement dashes? I've entertained the idea of repairing this one with glass or building a new one out of glassed MDF but getting a new one would certainly be easier
The fabulous fury of a Johnson 50hp :laughing:
Affectionately referred to as the Sea Nympho :grinpimp:
floor
wore-out carpet
