I decided to do my own maintenace finally this year. I have a Alpha 1 I/O Mercruiser. With the outdrive in the lowered position. When I put it into gear (either forward or reverse) it makes a very loud clank as it goes into gear. Once it is in gear and spinning the prop, if I take it out of gear and put it right back in while the prop is still spinning then there is no noise. I have always noticed a little bit of noise when putting it in gear while it is in the water. But I have never put it in gear while out of water. So is this loud clank normal? It doesn't sound normal. And yes I am flowing water through it as I am testing it. Now I do have a little bit of play in my prop (the prop slides in and out about 1/4"). Fluid level in the outdrive is good.
Thanks for any help.
