1994 suzuki dt115 Sneezes
josh5058
My 1994 dt115 makes a sneezing sound at idle up to around 2000-2500 rpm.
Could anyone give me and idea of what this could be? When I bought the motor there was some idling problems, so I replaced the throttle sensor and adjusted the flywheel position sensor. I did trouble shoot the whole motor looking for other potential problems, but everything looked within specs. Any help on this Sneezing would be appreciated.
Thanks ,
Josh
cousinabe
Re: 1994 suzuki dt115 Sneezes
Could be trash in the carbs, bad fuel pump diaphragm or needs a link and synch.
Have you checked your low pressure fuel pump is in spec? Does pumping the primer ball affect the problem?
Was it ever running right?
special_kaye
Thanks ,
Josh
Okay, I'm hooked and dying to see an answer for this one. I just had my second Susy-Q delivered and can't wait to get it installed.
elcamino12sec
Sneeze = a lean condition, not getting enough fuel. Find out what cylinder it is and adjust the carb accordingly.
josh5058
Thanks for the reply's. Its not trash in the carbs, I cleaned them about a month ago when I bought the motor. How do I know if one cylinder is running lean? Compared to the other cylinders?
James R
Manual calls for Idle jet screws to to be 0.625-1.125 turns out from lightly seated. Each screw will need careful and slow adjustment to get the optimum from each cylinder at idle. A sneeze is usually indicative of lean setting. Adjust the screws out to richen the mixture.
