Re: 76 6hp cooling question
Before you go getting nervous, the water pump is up high, where the four mounting bolts for the lower unit are. This sometimes makes it difficult to prime with a hose and muffs. So first thing, try with the leg submerged and see if that improves the water flow. If not, then you certainly need to replace the impeller.
NOW: With creamy or milky lower oil, this indicates water intrusion. If free water did not drain out first, then the leak is not too bad. First check the fill and vent screws for tightness and gaskets. Then, check the prop shaft seal for leakage. finally, check the shift rod seal and the drive shaft seal. All seals are still available.
Since you will have the lower unit off to check some of these seals, I makes sense to replace the water pump impeller at this time.
If I remember correctly, that impeller is more expensive than the ones for the larger engines: About 26 bucks. But, It is still available. Try The Chrysler Crew and
franzmarine@aol.com
