Re: Thru hulls vs thru leg back pressure test
a powerful sounding engine will make those who don't know believe your boat is faster... those who really know, don't care much about a few mph one way or another...
btw... the problem is really a LOT more complicated than just backpressure... unlike an auto exhaust you have the many and difficult not so subtleties introducted by putting water into the system... water is cooling the gas... dropping pressure, but adding density and momentum... and so where you inject the water stream, what temperature it is, what fraction of the mix it is, all are going to have a potential impact... btw, that water thing is likely why there can be a difference between boat with 4" when might not be with car and 3".... omg that makes my head hurt! How about this... with no mufflers, and 4 inch pipe exiting above the rub rail, my mess is annoyingly, obnoxiously loud... but that plus removing the spark arrestor requires several steps richer jetting to get the plugs the same color... and adds in the neighborhood of 5-7 mph on the top end. However, i roll with mufflers cause i like it better that way, and i keep the flame arrestor on cause I don't want to go boom... (or get a citation).
While you're at it, how about a temp sensor into the lube in the outdrive... I had someone tell me that a good reason to go with through hull was to keep from adding heat to the drive by running exhaust gas through it... Sure makes a lot of sense, but does it really make a difference in lube oil temp when you're leaning on the throttle for a while?
Alpine head unit, polk audio db series speakers and add the amp of your choice.
