Jeff the fisher
- Apr 21, 2009
- 10
I have a'68 40 horse johnson with hydroelectric shift and a '71 50hp evinrude. The 50 has a 3 button shift control. The 40 has everything on the stick for the remote (forward = forward, up = neutral, back = reverse.)
I would like to use the remote from the 40hp on the 50hp. The plugs mess together. One is black and the motor plug is yellow.
I don't want to use the control that came with the 50hp as someone unhooked some of the wires and the switches were replaced with a three position pull out type switch.
It looks like most of the wires on the controls match, but there are some that don't. Can I just switch around the ones that don't match to make the positions match and use the older controler?
Any help will be appriciated. Thanks
