no response to my last 3 post
allenprimo913
:mad: :mad: :mad:
just wondering, i got no responses on my last 3 posts.... anybody have any idea?
i ve been buying parts here on iboats for the last 6 mos. i have my boat and are you guys just very busy or what?
summer is coming and theres no reason to have a boat if its not running....
might as well change hobby.. flying maybe on air ....
:D :D :D
fishrdan
Re: no response to my last 3 post
Eh, don't take it personally. Probably,,, no one who knew the answer to your question or were too busy, better to get no comments than bad advice I say.
billgabbert1
i have had the same problem. needed help and no one has answered even tried sending private messages.
spktho
Ya, don't take it personally. Maybe just bump your post to the top with a reply from you adding any more information or just continually asking nicely for advice.
Dunaruna
Guys, nobody here at the iboats forums actual work for iboats, they are all boating enthusiasts like you and me. If you don't get a reply to a question, either it has been lost in the plethora of threads or the answer is not known. It could also be that the people who do know the answers are too busy fishing.
There are dozens of very skilled techs on these forums and NONE of them like getting PM questions. Unless invited to do so, I would suggest a technical question via PM will be ignored.
Bump your thread to the top at the beginning of the day, if it is seen, and the answer is known, someone will reply.
JB
Very few posts get ignored. When one gets no reply it could be that:
There is not enough information.
The post is unreadable because of poor or missing capitalization, punctuation, poor spelling.
Silvertip
In one of your posts you actually hijacked a thread asking how to post a new thread. I answered that question and it apparently got answered because you created this one. I also did a search and found no other posts by you. So give us another chance. Post again -- and not in someone elses thread.
allenprimo913
wow... lot of responses
and this one is not even about my problem issue on my boat
well. .. i apologize and im sorry, i guess you are all right because i can see lots of postings are not responded either.
it wont happen again.
im in the process of buying a plane...
:D :p :D
allenprimo913
i posted on april 21st ( 2 posts) and until now theres no any responses to them yet to my simple basic questions which i know somebody has answers for it.
but this one, i got 6 responses???????????????????? so far
:mad: :mad: :mad:
Hotfoot
Perhaps you should have tagged that earlier post, because you do not mention what the problem was in this post..???:confused:
allenprimo913
well might a well mention it here.
i have a 1966 110hp inline six mercury outboard
2 coils, 2 points, 2 condenser & 3 carbs
originally it was running fine 3 mos. ago then i ran out of gas 3 miles from the shore. the problem was the diapram busted out on those 2 fuel pump. i rebuilt the 2 fuel pumps and the 3 carbs and i replaced the 6 spark plugs
now my problem is when you re on the driveway with earmuffs on & running water it idles fine, run smooth ,but when you put it to gear it hesitate but
does not backfire, i can see lots of gas coming out from the carbs but doesnt acccelerate right, it boggs down at high rpm?
is this a carbs adjustment problem? i know i have sufficient fuel going in, could it be a spark problem? since i havent touch the breaker points?
any feedback will help what to do on this bulldog?
thnks
markmac
allen im no expert by any means but do you have the motor trimmed up in the driveway? if so that will cause the gas to pour out of carbs. what i have saw about adjusting carbs is turn low idle screw on carbs all the way in then turn each one 1 1/2 turn out, then adjust each, starting with the top carb and work down turning no more than a 1/4 turn per carb to get it running smooth. i had a problem with my 1980 115 cutting out and bogging down on the lake but running fine with the muffs on, turned out to be my rectifier. i hope this helps you out.
crazyclam
I also suggest syncing the carbs by turning them in and backing out 1/4 turn until it runs smoothly.....sounds like its getting too much fuel, possibly fouling your plugs....especially after a rebuild, all nice and clean jets will flow more fuel than old clogged ones...
Silvertip
It is also possible that the float level is not set correctly, the inlet needles and seats were incorrectly installed or not sealing, and that one or more of the floats is incorrectly installed.
new boat guy
if someone doesn't respond to your post just add a a post that says bump to said thread and maybe repeat the question in a clearer manner
Alumarine
Actually here's the deal.
All of the knowledgeable people who normally help others, have made so much money from helping others on this board that they are all out on their mega yachts with their super model girlfriends.
film495
What do you mean you can see gas coming out from the carbs?
allenprimo913
if you look WOT , you can see gas inside the carbs
but maybe i should try replacing my rectifier for a change. there is no switchbox on this babies???
old model actually but i guess its a strong motor if it runs right
thank guys
allenprimo913
i check my rectifier here but all the pictures are different.
mostly i saw here are square mine is a rectangle type that has 3 terminal on top not like the one square black in color.
is it safe to use this black sqaure ione?
xxturbowesxx
have you rebuilt the carbs? I would at least remove and check them as a first step(not the easiest job but usually the problem)... I start by checking the carbs then work backwards from there to the fuel tank.. then I check ignition starting from the plugs and then back from there.. The boat bogs in gear because you are putting a load on the engine and it isn't producing the power it needs to maintain idle..
also a rectifier is not going to effect the running condition of your boat.. It has to do with the charging system and the boat will run find without one.. Although your battery will die and no Tachometer..
