I have a 1973 Johnson 50 Hp Motor. I have done everything to it - including replacement of power pack, rectifier, coils, fuel pump, in addition to rebuilding the carburetors. Finally got it run. It starts up with starting fluid -runs for a little while with me holding the throttle in a midway to high position. Within about a minute or two it dies on me. It almost acts like its running out of fuel. If I spray starting fluid it starts up again but doesnt last. I noticed that the primer bulb also becomes flat. I tried moving the fuel tank really close it to limit the length of fuel line suction since I have a 12 gallon tank located in the middle of the boat but that did not work. When I removed the carbs I noticed that you could see daylight through one of the leaf valves. I am wondering if the engine is not creating sufficient suction to make the fuel pump diaphram work. The engine has good compression - 110 on both cylinders. Any ideas - I am about to give up on it and buy something newer.
Appreciate any advice. Its not heating up because I disconnected the sensor.
