Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
5000 to 5500 is the optimum operating range. If the motor is running up to 6000 rpm than the risk greatly increases that it may suffer mechanical failure as that any ventilation of the prop, at this point, will cause undo stress on the rod bolts. Hope this helps.
Thanks for the quick reply. One more question. I pulled the prop off to check it. It has a 12 3/4 inch 21 pitch prop on it and I am running it on a boat rated for a 150 hp max, a fish and ski. Will that prop perform well?
