Last year I replaced engine on the boat, 1996 Volvo Penta 4.3L GL. After that, had some issues with water getting in the gas, fixed the problem and replaced electric fuel pump that had crapped out recently. Sounds good in neutral, starts up easily. However, took it out last weekend for the first time in 5 months, and it would lose power when throttle was moved past 1/2. At 1/2 throttle, 2,000 rpms, above that, rpms dropped, sounded like it wanted to cut out, not much power at all. However, when I would pump the throttle back and forth (not all the way, about and inch or two, but repeatedly), the boat would get up on plane and hit 3500 rpms for as long as I would pump it. Stop pumping, back down to 2000 rpms or less. Again, in neutral it doesn't have such an issue.
I have someone coming out to look at it, but I would like to have an idea of what to look for (in addition to the "Engine won't reach operating RPM checklist"). Thanks for your help!
