Using "MUFFS"
fakeplay
Banned
How is one suppose to use "MUFFS" for flushing out an outboard ? Are you suppose to just run the water without starting the engine or do you run the engine while flushing ? Thanks:confused:
kenmyfam
Re: Using "MUFFS"
Attach muffs, run hose to muffs, turn on water, make sure intakes are covered, start motor to pump and circulate water around the motor.
fakeplay
Banned
Re: Using "MUFFS"
How do you cover intakes ? on a "62" 71/2/ hp fishing scott ?
EN2
Re: Using "MUFFS"
Plastic trash barrell works for me. Fill it up high.
