I recently replaced the lower drive water pump on a eight year old Alpha One Gen II sterndrive. When remounted and on test with the rabbit ears, engine temp is OK at idle, will not test at higher revs until I get it in water.
My question is, how do I tell if I have transom or thru prop exhust. On test, all of the exhust and a lot of the water was comming out from the transom area. But some water was comming out the prop area (prop removed). Can anyone give me an overview of the two types of exhusts systems on the sterdrive. Also the water outlet.
The more work I do, the more I see needs to be done. I thought replacing the water pump would be a good preventitave maintance project. The reaility is that I now need to replace the thermostat (very small project), and am wondering if I should be replacing the exhust tube and bellows, gimbil bearings etc. Where does all stop? Considering the cost (time and cash) it may be better to just get a referbished stern drive.
Anyway, the last few line were just a little rant, but I would appricate any help with the exhust and water outlet question.
