Hate to sound stupid, but I am lost. I just bought a 15' Lund fiberglass fishing boat. When i got it home we noticed a gash in the hull. I goes pretty deep, it's about 4 inches long about a half inch wide and at least an inch and a half deep. Anyhow my friend told me to just get some fiberglass repair kit mix up some, put in some fiber matting (not sure the proper term) and fill the hole. Of course I tried the best I could to clean out the hole and sand it first. Anyhow just under the fiberglass is what appears to be foam, so I picked out as much as I could and filled the hole.
Well while sanding the patch down, I noticed a few drops of water coming thru the patch. So I spent some time and got the patch out, and tried it again, this time picked a lot more of the foam out, made the hole a little bigger. Patched it and same thing a little water seems to be coming thru. It hasn't rained in 4 days, not sure if the foam under the fiberglass is just waterlogged or what. Any ideas on what I can do to get this patched? There isn't water in the boat why is it coming thru to the hull? Sorry so long just would like to get this boat in the water.
